1 - 3 of 3 Posts
So I removed the nissin master and installed a 19x18 Brembo with same brake lines and a fren tubo adaptor because stock line isn’t rotatable. I replaced the fluid to rbf600. I bled the right side (caliper closest to the master) bled super easy no issue, bubbles were out in 1 min. But when I bled the left side (farther away from master) I almost went through the whole bottle of fluid and still kept getting blobs of bubbles coming out of the bleed valve. I left the lever zip tied to the throttle overnight and cut it this morning and the master feels great and the lever won’t come all the way to the throttle. So question is, is all air out of my left side, I kinda gave up because I kept refilling the reservoir and I was still getting bubbles till I almost ran out of fluid. The lever feels great but I’m worried there air left in the left brake line or not? Is it normal to have a little air there?
An R1 kinda day!
2015 Yamaha YZF R1 Raven Edition
Not normal for air to be in the brake lines. Not sure what happened there.
1 - 3 of 3 Posts
