Bottomed out front suspension help?
472 Views 10 Replies 4 Participants Last post by  Gearheaded
I have a 2020 R1. Hit a pretty big pothole broke the front wheel, bottomed out the front legs and twisted the alignment to the right.
Looking for advice on what to do with the fork legs and upper and lower triple tree. Inspect and Rebuild? Or just replace everything? Thanks in advance for the time and help everyone.
1 - 11 of 11 Posts
Pictures??
The forks might just be twisted in triples but everything can be loosened up and put back.
might also be a good time to clean and grease steering head bearings
i could only imagine what that felt like on your wrists😳😳
  • Like
Reactions: 2
Agreed- hopefully the forks are just shifted in the triples. Have a headlift front stand ? If not you’ll need to get the front supported up without using forks. Remove the front wheel/loosen clamps just enough to be able to slide forks. Use the lines at top of forks to gauge height. Make sure all is straight/even and try it out. Good luck!
  • Like
Reactions: 2
Typically I agree, but it’s actually better to line the axle centerline with the bottom of the bottom fork leg. You want to match the center line of the axle between both fork legs. Using the top will get you close, using the bottom will get you perfect.
OP. Pics would help, 👍🏻
  • Like
Reactions: 3
Pictures??
I actually barely felt it in my hands. The tire took most of the damage. I'm pretty sure it was just twisted in the triples. The fork legs seem straight. They aren't leaking oil. And still function. I'm concerned about possible micro fractures, damage to the internals etc. Probably just gonna take em to yamaha and have them rebuilt reseal and new oil. Going to pull the triples and replace the ball bearings with tapered rollers but need to build a tiny gallows to hang the front end from. Any damage to keep an eye out for on the triples? Pics aren't great but it's all I have. Thanks again for the help
  • Like
Reactions: 1
Doing the alignment is easy I got that and yes im fairly certian it just twistedin the tripples, it's suspension I don't know. They're the stock kyb that came on the thing. I'm concerned about damage to the internals. I'd get a rebuild kit and do it my self but I don't know what I'm looking for damage wise. Anything micro fracture wise to look for? The lower triple is pretty stout I doubt anything happened to it but then again it is aluminum. Anything to look out for there? Building a tiny gallows to hang the front end from to get the triples off and then I'm going to replace the ball bearings with tapered rollers. Anything else I should consider or am missing? Thanks for the help my guy.
Honestly I’d put a new wheel on and change the fork oil or just service the forks.
you’d be amazed at how good today’s suspension is. Dealer isn’t going to be able to find anything other than a leaky for seal.
Id do some research before you change the original head bearings from ball to taper.
The feel is very different and I believe the top teams in racing still use the ball type for that same reason.
I’ve used Jack stands on my frame saver guards to hold up front end complete on my 03 Gsxr1000 before.
  • Like
Reactions: 1
Sweet thanks man. Makes me feel better about the whole deal. Definitely gonna do the service. Will look more into the bearings. All the videos I see on servicing the triple tree bearings, everyone always changes to tapered. Just assumed they were the better option. Lol but I saw it on YouTube so it has to be true right lol. And yes modern suspension is amazing for as bad as the wheel is I didn't hardly feel it except where it bottomed out and that part was "hardly felt it" part. Also been watching alot of Dave moss stuff good resources. Thanks again for the time Jimmyboy. Keep that rubber side down my guy.
  • Like
Reactions: 1
You’re welcome Patrick.
let us know how it all turns out.
im glad you weren’t running carbon wheels!
Yeah Dave moss knows his sh$t
No s#!t right. Cast magnesium on the 2020+. But I feel like the wheel failed as designed and absorbed most of the impact. Definitely will let u guys know. Can't wait to get up again.
  • Like
Reactions: 1
No wheel is gonna take that header and survive. I’ve seen it in steel wheels just as easy.
I wouldn’t worry about fractures in the internals. As Jimmy said, seals and oil, and ride it. See how it feels first before you drop a grand into a fork set that doesn’t need it. The triples are most likely solid, and it’s probably just the wheel. I’ve had some really nasty crashes and never had a problem with the triple, it’s usually just other bent wheel or bent fork first.
the internals aren’t a cartridge like others have been, it would be hard to pull it all down to parts for examining. Not impossible, but you need to break the loctite inside the tubes and you need special tools.
personally I think because they’re sprung with fluid, they’re only going to compress so far before they will simply just force the fork legs to bend or snap. If your forks are straight I’d say the internals are most likely ok. Ride after a fork service and new wheel, see what happens first. It won’t be dangerous, it’s not like the suspension won’t work anymore, it just won’t feel smooth or “right” at first. There isn’t much in there that can go wrong.
  • Like
Reactions: 2
1 - 11 of 11 Posts
