1 - 3 of 3 Posts
I recently installed a Brembo Corsa Corta master cylinder and haven’t found any info regarding the brake light switch.
I’m going to replace the bullet connectors with spade connectors to fit the factory wiring but does anyone know what wire connect when wiring it up?
Hope is what makes us Human.
If your changing the OEM master cylinder to a race unit. It will delete the OEM light switch. You will no longer use the switch box but just the two wires from it, to connect tot he pressure banjo switch.
something like this.
I'm an Englishman in WI.
It doesn't matter which goes where.
1 - 3 of 3 Posts
