1 - 20 of 33 Posts
WSMC #520
No they won't. The 05 R1 has a 5 bolt pattern, these have a 6 bolt. However if you had a set of Marchesini wheels they would bolt right up without the adapters.
Ya whatever, save it
If you take the adapters off that allow you to run your stock rotors ( in your case the Galfers ) then those Brembos will bolt right up.
The rotors themselves aren't lighter..... but the combination of your Galfers and the adapters probably makes them close. You wouldn't be purchasing the Brembo's for weight savings though... it would be for performance. The Galfers.... at least the ones it looks like you have, are stainless steel. The Brembos have higher iron content in the steel for a better coefficient of friction ( better stopping )
do you have any pics of them on the wheels
also do you have any more information on the rotors like part number, or anything that will give any specification.
and i have galfers do you want to trade :lol
WSMC #520
Discussion Starter · #12 ·
The offset is 19.5mm. I don't have a part number for them because I already traded somebody else for them and they didn't give it to me. I can get you a pic if you really need one:lol
what does OWO style mean, i have marchesini's and i would like to know if they fit.
what is your reason for you to sell them, and also you would not want to trade for galfers
WSMC #520
Discussion Starter · #18 ·
The reason I don't want to trade for the galfers is, I already have a set of Brembos for Marchis. I don't need an extra set of rotors. I traded someone a set of tire warmers for these.
WSMC #520
Discussion Starter · #19 ·
You have to do some measuring on your marchis. You can see in this pic that the rotors are meant to be put on the wheel itself, not the adapter. The measurements for the rotor are listed in the first post.
For what it's worth..... I'm the guy Brian got the rotors from. They came off of a Marchesini race wheel which uses a bolt patter of 6 x 80mm..... you can see in the picture Brian posted the Marchesini he has, has an adapter bolted to the wheel to allow the use of the stock rotors. The adapter is bolted to the wheel using the 6 x 80mm bolt pattern..... ( see the images I've posted as well )
In the first image is a direct bolt on Marchesini ( blue ) it hase the same type of adapter.... if you remove the adapter it looks like the secong image ( except that wheel is a older 5 spoke )
If you remove the adapters... then the Brembos will bolt right up to the wheel. The question then becomes will it still go onto your bike. The Brembo's here have a 19.5mm offset..... most Yamaha's at least to the best of my knowledge have 130mm spacing for the rotors ( give or take 1mm ) so, knowing this...... your hub after you remove the spacers needs to be 91mm wide where the rotors would bolt to the wheel ( again give or take 1mm ) from here you should ( or anyone for that matter ) be able to do the math and se if these would work on your bike.
The other issue is that these are narrow band rotors..... if you don't know what that entails... these might not be rotors for your bike ( sorry B, just trying to be honest ) you wiull need calipers designed for narrow band rotors... or you will have to modify the pads in your calipers to work with these otherwise the pads will contact the " buttons " that attach the rotor to the carrier.....
1 - 20 of 33 Posts
