1 - 6 of 6 Posts
My R1 eats my bank account
Hi guys
I got a problems with my bulbs. I've noticed everytime I go for a high speed ride, one of my headlight bulbs always die. It happens to no particular side but proberly more on the left headlight. Has anyone had this problem before?:dunno
mmmmmmmm.........I dont think so;
I had this problem with mine,but only when it was brand new.
Had this with the TLS also.
Cured the problem when I added some reflective prisms in the headlights which made the H4 tighter.....not sure if it was really related or not,but I"m on the same bulbs since early 99 and they have A LOT of mileage on them...on bumpy roads most of the time too.
The biggest Woody!
check the main connector to the headlight wiring. undo the plug and see if the conection is corroding. If its turning green in there you should clean it and that will probably cure your problem. I had the same thing happen with my 99.
Discussion Starter #6
Thanks for the advice guys,
I'll take a lookie when the wealther gets a little better (no garage). Crappy melbourne wealther.
1 - 6 of 6 Posts
