I have been trying to remove the shear bolts from the upper triple of my 2004 R1. I've had absolutely no success so far. I don't care about the old ignition because it has an intermittent short that causes the motorcycle to shut off randomly.
These bolts just won't budge.
First I drilled into one of the bolts and attempted to use a #1 screw extractor. I got the screw extractor in pretty far but ended up breaking it off in the bolt.
Next I tried using a chisel and punch to rotate the bolt. It didn't move.
The next day at work (which is today) I started to grind the ignition off, but realized that I would still have to deal with the bolts after, so I used the grinder to make slots for a flathead screwdriver. They didn't budge.
I tried using kroil oil and letting it sit for an hour –the bolts wouldn't budge.... even when I used a vise and adjustable wrench for torque.
I used a heat gun to head up one of the bolt housings, still wouldn't budge.
I have no idea what to try next. Even if i grind off the ignition and leave the bolts intact, I doubt i'd have any better luck trying to unscrew them from the shafts
