A PM question just triggered this, so here we go:
Well, I mentioned it in the fender-eliminator thread, but won't hijack said thread and rather open my own.
I have built my own "fender eliminators" on past bikes (I think the one for the 05 R+ was documented on here) and the 2015 R1 for sure needs to have some work done there.
So I am currently designing my own fender eliminator.
I thought it's time to share my thoughts and listen to potential good ideas that might come up.
Here is the design constraints:
1) Should work for EU license plates (200mm high at max 30deg from vertical) without interfering with the rear wheel when at the "fully up" position, although my own Swiss plate luckily is smaller. I plan to do a limited production on those.
2) Must have reflector and license plate illumination
3) Must protect the passenger from spray (the "wings" on the stock device have that purpose imho)
4) Made from carbon
I did some sketching to find the proper position.
Here is what I came up with so far. Drawing is one thing, seeing it on the bike is something else.
So I am going to glue together a design piece from PVC sheets, just to get a visual impression.
I will then judge if the result is optically appealing or if I will discard the "EU plate" requirement to get some more freedom to design "under the tail".
(Yellow = EU license plate / Red = Swiss license plate, the US one would be much smaller, Blue = Reflector)
4) Made from carbon
