1 - 15 of 15 Posts
· For those about to rock
Just kidding. 520 refers to the chain width which is sometimes preferred becuase they are lighter than stock chains and I'm sure a whole bunch of other mechanical and law of physics reasons. You need 520 width sprockets to use them though.
480 is the resolution of older IBM monitors :)
· Banned
And then you've got 420.....:bandit
· Action figure sold separately
Well, it's Daylight Savings Time starting at 2:00 AM Sunday, so tonight before you go to bed, you should set your chain back one hour.... :crash
· Registered
When you take off the seat , right next to the battery is this black box looking thingy. It will have a some dipp switches on it. All switches up is for 530 setting. First two up last two down is for 520 setting. All down is for 480.
Good luck.
· Cheating death in the "D"
Ponykiller said:
Thanks for the link, but I gotta ask, what makes that worth 90 bucks, when I already have a laser pointer I could probably use?
probably nothing, if you can fab a mount to hold your pointer perfectly level, that would work. The key is getting it level, and having a base that fits on the sprocket, in a location to gun sight down the chain :thumbup
1 - 15 of 15 Posts
