thinking of getting the clear alternatives integrated tailight kit for my 07 r1. any opinions... pro's cons?
make your own bracket.thanks i just ordered it along with some flush mounts. any recomendations on a license plate bracket?
:stpd:make your own bracket.
Exactly what I did. I should have mentioned it. Taking off the muffler allows you to get to the wires that run under a little tunnel. Like he said, it will make sense when yo see it.The wires for the taillight run between the plastic bodywork and the subframe for about 8 inches or so till they reach the connector. You'll see what I mean when you get it apart.
The easiest way to get the wires through there is to remove the right muffler, then take the plastic bodywork loose from the subframe. Sounds alot harder than it is.
I've been wanting the pivot kit. I guess now is the best time to get it since they are having a sale.Check out these sweet tailights from VFX at www.vfxkits.com
motomummy.comi want one. whats the cheapest place to buy
