Ok, so they called for beautiful weather here in Cincinnati today, so I thought I'd get my bike ready to ride....
Since I laid the bike down in November, I've been working on getting her back to snuff. I should note, that after laying her down, I got up and kept riding....so there were no problems with the bike other than cosmetic.
One of the items broken was the clutch handle. So I replaced the handle. No big deal - or so I thought. I also finished an oil change at the same time, and took a look under the tank to make sure everything looked ok.
But now she won't start....probably because of sitting all winter. So I thought I'd try push starting....but now the clutch doesn't work. WTF? I only replaced the handle, and it worked fine the last time I rode. I pull in the clutch, can see the mechanism pivot down by the transmission, but won't disengage the gears. So I tried adjusting the spin dial on the handle....nothing. Tried tightening the nuts down by the trany....nothing. Still won't disengage the gears.
So after all this, I'm looking for a little feedback. I am NOT a mechanic - but noticed that fresh oil is poured into the same cavity as what the clutch mechanism is mounted to. Does the engine need to run a bit to get oil down by the clutch? Any other ideas on what might be wrong?
A little help please? :-(
Thanks in advance. I SO want to go riding this weekend.
