1 - 9 of 9 Posts
· Registered
Here is the problem im having, the symptoms:
When i press the clutch lever all the way and put it in first gear. the bikes pulls forward a little and sometimes it even stalls, so my logical thinking is that the clutch is not engaged all the way.(there is very little slack on the cable, just enough).
I just changed the clutch (ebc sbk kit) this morning and still the same problems. I have that Graves Clutch mod installed. I even removed the Mod hoping something would change. but the clutch feels exactly the same. Im running out of ideas. I wonder if it could be the clutch cable. Im so frustraded with this already. I have taken that clutch apart a least 6 times in the last 2 days! HELP!
If you need more info let me know!
· Registered
Discussion Starter · #4 ·
Clutch adjustment can be a pain.
After I installed the YEC springs and Graves clutch kit, my adjustment was way off but I finally got it right.
It's you clutch cable adjustment. I'm sure nothing else is wrong.
I installed the springs that came with the Kit. The only adjustment im aware of is the slack in the cable i thought that as long as the cable is not loose , having just enough slack, it was the only adjustment. What others adjustment can be made?
Thanks for the help
· Premium Member
Thanks for the help
There is the adjustment ender the clutch cover and the clutch cover itself. Make sure the over is installed correctly.
I had the exact problem your having and playing around with cable adjusment solved the issue.
1 - 9 of 9 Posts
