1 - 3 of 3 Posts
Hi All. I have a 2008 R1. I have just removed the clutch plates as my clutch kept slipping. Plates are perfectly fine however behind the plates there were multiple loose bits and pieces. Is this normal or not. Especially from the pin hold pieces
Could this have been worn clutch material?
Loose bits and pieces sounds like possible clutch material, or something let loose in there.. Sometimes it can get a little gunky from clutch wear but if theres pieces id suspect clutch pieces or check with a magnet and see if its some kind of metal.. Did you clean it out and put it back together and test ride it? Still slipping?
1 - 3 of 3 Posts
