1 - 8 of 8 Posts
so.. in a nutshell, my throttle bodies connect to the head via these 1-2" long rubber tubes with clamps on them.
well, the throttle bodies popped off..
and i can't shove them back on with the clamps tight. and i can't see how to get an allen wrench down to tighten the clamps if i loosen them and put the throttle bodies back in place.
only thing i can think of is dropping the motor. help??!
anyone??
i know this has happened to one guy before who accidentally put diesel in his R1.. gonna try to find the thread and PM him..
2 wheels are better than 4.
You can either get an extended Allen wrench like what lil R! recommended or you can take off your tank and air box and use a little one by squeezing your hands in there - that is how I have done it two separate times now. I really should get the longer wrench it would cut maintenance times in half when working with the throttle bodies.
Good luck bro.
WFSR************
Good luck bro.
I tired your description beofre, it was a pain ...a big one too
WFSR************
actually there are just drivers that are at least !.5 foot long..you don't need tbhe whole seet, jusyt a long driver that is it...cost around $10-15
I had the same problem and same headaches as described by the others. First thing I did was take the rubber couplers and cleaned them really good with carb cleaner so they were'nt oily anymore. Then I attached them to top of the manifold and tightened the lower screws. (easy without the carbs getting in the way). I then took a little bit of WD-40, sprayed it on my finger, then swabbed the inside of the rubber sleeves so they'd slip on easier. I then positioned the carbs over the holes and rocked it back and forth till they slipped all the way down into the rubber sleeves. Then using the long T handled allen wrenches I tightened the remaining four allen screws. No getting around it, tightening those screws is a total bitch.
1 - 8 of 8 Posts
About this Discussion
5 Participants
isagani
Full Forum Listing
