yep, got them on right. both sliders are the same length and came preassembled with an aluminum sleave in the center. the only difference was the sleave is longer on one than the other, but problem was they only drilled the slider so the sleave will end at the exact bottom of each slider :no . that means the sleave does nothing for you other than position the bolt head out more :dunno . i stalled it every wich way. after it didnt fit i got the idea of taking the sleaves back out, and swopping them. put the longer sleeve in the deeper hole so it would estend past the bottom of the slider so it would go into the fraim hole on the left side and then take the shorter sleeve and put it in the shallower hole so it will fall short of the bottom of the slider so it will sit flush on the frame and not the sleave on the right side. Kinda hard to explain. that realy didnt fix the problem beacus now the sleave on the right side is too shallow and the sleave on the left side sticks out too far. so i cut the sleave on the left side so the slider fits perfect to the fraim and the sleave tightens the motor back up to the frame, then I cut the slider on the right so that there was only 1/16" between the slider bottom and the sleave. i think i did some drilling too but i cant rember what i ended up doing. all and all, they are crapy sliders and im glad i can make them work.:machinegu Lockhart Phillips:boom
