1 - 3 of 3 Posts
My R1 belongs to someone else!
on my old bike i was wondering after it was looped by a friend and did some extensive bike to concrete mating, it wont start, the starter turns over, is there a fuel cut off, something with the tip over sensor, if so how do i reset it to make it start, most damage is cosmetic, any suggestion appreciated? would like to get started to stunt it when i get home, it is 2003 r6
A Little BRIT Different
Tip over sensor
Hi there
I had exactly the same problem when I crashed mine at over 100, it went end over end,, yes a brand new R-1 Raven but after rebuilding it I had the thing die on me
It was the tip over sensor,,, it can be reset, I had to pay my local dealer to do mine for $11 but I believe that if you hit the kill with the ignition switch on switch and then turn off the ignition switch and the engine kill switch, it resets itself, in the workshop manual this is mentioned, you should also get an error code if your confident going in to the diagnostics menue, also mentioned in the workshop manual
Good Luck
Martyn
1 - 3 of 3 Posts
