1 - 3 of 3 Posts
Hey ASSHOLE I am 911
I am getting some clutch chatter. Is this normal? My clutchgrabs fine and is fairly new...about 4000 miles on it...ios this a normal hting...stops when I pull the clutch in....
working on that new bike
normal. your clutch basket takes repeated abuse when engaging/disengaging your clutch....thats what you hear.....I worried about same thing a few years back on mine and had a mechanic friend take a look at it and said it was quite normal as his TLR at the time did the exact same thing as mine
So I actually took it apart because the chatter is really loud. It akmost sounds like a DUC...Sorta....It stopts when the revs are raised from 1500 up to 2000 and if I pull the clutch...I took the thing apart...checked that the boss nut was tight...it was...torqued it to 69ft/lbs and then reinstalled the plates the same way I took them out....saw nothing wrong and very little wear on the clutch.....What could the problem be?
1 - 3 of 3 Posts
