Hi to all. I?m riding a 07 R-1 that is stock except for the lowering kit which I have no info on. It was the lowest they could get and installed by dealer. The front was lowered to match. I don?t race or trick with mine, so the suspension settings I?m looking for are on the smoother side. Although I?m considering going out to the road course at Moroso just for fun. I have read many settings info (One included below from Jeffrey De Vries) but I have yet to see some explanation of what affects some of these settings cause. My particular problem is that when hitting little imperfections in the road it reacts like I have big flat spots in the front tire. You can easily see it in the headlight beam bouncing up and down. So I would think that adjusting the rebound softer would solve it. I have not tried as of yet, but I know that descriptions don?t always represent their actions. So maybe a softer compression with faster rebound might be the answer. Anyway if someone out there could explain what will happen if? I would be grateful. I weight 185 and this problem was present before the lowering kit. Thanks in advance and I look forward to reading through this forum. Here are the settings I found for anyone interested. I?m not using them or even tried them. I think they are more race oriented. Sorry but I can't remember where I got this from.
Doug
2007 R1 TRACK SETTINGS
From Yamaha test rider Jeffrey De Vries.
All settings from fully in (except preload)
Standard settings in brackets
Front
Rebound 8 clicks (10)
Preload 5 rings showing (6)
Compression 8 clicks (10)
Rear
Low speed compression 1 click (12)
High speed compression 3 turns (3)
Preload 6 notch (5)
Rebound 11 clicks (12)
Doug
Front
Rear
Preload 6 notch (5)
