Hey everyone, I have a 2006 R1. It will turn over and run then stumble and die. If I put it in a higher gear it will idle for a few seconds longer then die. Now before you go crazy saying this has been addressed listen to everything I have changed.
I have put in new plugs which are getting spark, i have swapped out the throttle bodies, injectors, fuel rail, fuel regulator, fuel pump, battery, made sure there are no kinks in the lines, the butterflies open and close on ignition, i have tried two sets of TPS's, i have done the lean angle sensor mod, I'm litterally at a loss. If i put the bike in gear and hold the clutch in then it will pull it a little.
Also, if i do as much as bump the throttle it will not rev and it will kill it, However if i open the throttle while I try to start it then it will recognize the throttle and rev upon start up then die.
Also, when I'm in gear holding the clutch in it is nearly impossible to push the bike.
Please tell me someone has an idea. I'm seriously at a loss. :saw:
