They both will work equally well on an '06, since there is only 4 lower injectors on an '06 to control. I have a Bazzaz on my '06 & '12, and use the Z-AFM to tune with. DynoJet's Autotune is very similar, but both units need an O2 sensor bung welded into the stock header to use. Either company has downloadable maps on their sites, depending on how close each of their maps is to your actual bikes needs, that will determine how good it runs. A dyno tune costs about as much as either ones 'Autotuners', but with a lot less work needed on your end.
