It's all about the rider. In a serious drag race, all of these bikes can pull up the front end in first, second, and third. You've gotta have skill to get the most possible acceleration out of the bike. If you don't have the skill, you WON'T have the speed. You aren't beating a Hayabusa, Gixxer, R1, or 954. You are beating another rider. You smoked somebody riding a Hayabusa, or somebody riding an R1. And know this, as fast as you are, there will be somebody out there that is faster, and they won't always be on an obviously more powerful bike.
My suggestion to steama, get used to launching and running the stretched R1 without nos first. Once you've got that down, look at getting a nos kit that provides several boost settings. Start with the lowest and just work your way up. On a stock R1 engine you could run a 50shot pretty reliably (assuming everything was set up properly. If you're running lean, even a 25shot can damage the engine) I wouldn't wanna do more then a 75shot without any other mods though. That'll put you over 200hp on a basically stock engine. At that point it's time to work on using that power some more. You'll have serious traction problems with that much power, and you'll still be able to bring the front up if the traction is there.
