1 - 7 of 7 Posts
· Registered
messing around in the garage today and went to mount my lap timer and my triple tree sit's at the very top of the forks. My question is if I drop them enough to support the ring clamp will it alter the geometry of the bike and if so how much? thanks in advance guys!
-Kyle
· R1 Forum Star
Yes it will and yes you will notice. No I wouldn't lower the bike..I raised mine 5mm in front and a lot in back to help with ground clearance.
If you drop the front you may like turn in better, but I wouldn't want to lose ground clearance.
· Im Lovin' It ;)
imho:
when i dropped my triple down the forks, i noticed a difference in handling almost instantly. from what i can remember i could turn the bike into the corners alot easier. sticking with the principles of "pro cornering" its great. BUT ground clearance became an issue more than once. i also had to stiffen the front which lead to a few APEX challenges.
in short i would try raising the rear and MAYBE lowering the front .5 - 2mm. as said above, these R1's are already really close to the ground in the front.
· kickin' at the darkness
raise the rear b4 you drop the front... SBU has their adjustable linkage, it works very well.. i'd like to raise the front a little myself :yesnod
1 - 7 of 7 Posts
