1 - 9 of 9 Posts
RD350YPVS reincarnated as R1
Hi all,
I have a Haupuage PVR PCI video-capture-card which has limited use under Windows XP but should work OK in Win'98.
Can I have a dual-boot set-up (Win98/XP-Home) with a single hard-drive formatted as NTFS.
Would a better option be to buy a couple of hard-disc caddies and a second hard-drive allowing me to swop drives to swop operating systems (before boot-up obviously)?
Duncan.
DAMN YOU SHANE
you can partion the hard drive and it should work for you
Heh
Yea you can use partition magic or other partioning program to make a seperate partition on the same physical drive and install 98 on it. XP's boot menu will pickup 98 and give you the option to run 98 or XP after you install it. But what I'd do to make things easier is just install Virtual PC which will allow you to install multiple OS's from within XP, and run then at the same time.
Check it out here..
http://www.microsoft.com/windowsxp/virtualpc/
and it's made by connectix..
http://www.connectix.com/support/vpcw_online.html
LeXo
El Assholio Supremo del Mundo
Phoshious said:
In all the years I've used Partition Magic, I've never had anything go FUBAR.
Me neither, and i just setup my laptop for dual boot with linux and xp with it.
I use it all the time, works fine
If my R6 had boobs,I'd lick'em
downloaded my version off kazaa, so was prolly ****ed up anyways and I couldn't make a back up diskette because I don't have an A: drive on my laptop, heh
Went ahead after that and used linux to partition for me
R1Budha what distro are you using?
WinXP / Mandrake 8.2
Gonna change to redhat 9 tho. i like it better.
not that i use linux a lot, but i'm learnin!
used part magic 8 to part the drive. took about 3 minutes and viola done.
1 - 9 of 9 Posts
