Easy,Cheap '04 GP shift
Everything can be had at ACE Hardware:
2 ea. 1"Dia. X 1/2"W X 3/8" hole Collar stop
2 ea. 8mm X 45mm 12.5 grade bolts
1 ea. 6mm X 45mm 12.5 grade bolt
1 ea. 12" X 1/4"ID .050 wall alum. tubing
Update 4/27/06: Go to Pg. 3 for upgraded part and #. Stock shift arm started bending and I replaced it with this and have had no further problems what so ever in over 2 yrs. of service.
Disassemble the rearset and Shift rod assy.
The 2ea. 8mm bolts need to be trimmed 13mm. This allows for the most unthreaded shank going thru the rear set and spacer.
Cut a piece of the tubing with a tubing cutter at exactly 1", no less.
Remove the Shift shaft lever on the motor. Remove the Hiem joint by removing the attach bolt under the rubber boot. Install the spacer, Hiem joint, and new 6mm X 45mm bolt w/washer back on the shift shaft lever with locktite. Reinstall the shift shaft lever so that it's 90 degrees to shift rod. Install the 1/2" thick collars behind the rear sets and torque! Your done! Works great and inexpensive!
