1 - 4 of 4 Posts
Dis Microphone Explodes
At high revs and higher speeds, the engine starts to get all choppy like its about to bog out. The tach needle also flickers around like crazy. Anyone have any idea what this could be. I don't think it's electrical.
Ghostrider Squadron
plugs?? or stopped up airfilter. start with easy stuff. also check to make sure that you have full 12 volts on battery. it should be like 12.6 with key off and sitting for few hours and if you rev to 5k it should read over 14 volts. just a thought. good lukc
thanks alot...i'm going to check all that tonight...
:D
Mustang Hater!
Sounds like a bad ground, or a poor connection with the spark plugs. Whenever I have something weird start happening, I cover all the basics by replacing all the simple things that probably should be done just for the hell of it: spark plugs, oil, oil filter, fuel filter. If that doesn't fix it, then you know it's something else.
1 - 4 of 4 Posts
