1 - 4 of 4 Posts
· Uni Shooters! Bottoms Up!
i'm tryin to find out 1 of two ways to do my exaust. first of which the first is the easy way, which i would rather not do due to the fact that i can't easily afford it, being that i would have to find someone who would want to buy a set of akropovic carbon slash cut slipons and then order my full system. the second of which is much easier if i can find any way of doing it. is to some how somewhere order the akropovic headers(collectors) and just order those, does anyone know of any way i could do so, the other idea is to order the arrow headers, the only problem is that the shops i have talked to say that they wouldn't match up, which doesn't make sense cause it would be going into the y-pipe, not directly into the cans. if anyone has any ideas or suggestions i am open to them.
· Speed is bliss!
I just installed the Arrow header on my 04R1 with a Termignoni Y-pipe and cans. So, based on that and the fact the Arrow states that if your slip ons will match up exactly to the stock Y-pipe/cat, then they will fit. Just as a side note: My termignoni slip ons matched up to the stock Y-pipe so if your akro's do then I suspect the Arrow header will work for you. Just my .02!
yeah thats kinda what i was looking for, i been looking around and found one of the other posts on this, just after i had posted this one up, but yeah, the regular shop i usually go through was looking up everything as best as they could and we had decided that there shouldn't be any issues, Termi also does a set up but i would have to make some tweaks here or there, and akro doesn't make just a set of headers, the only way to get them from my knowledge and the guys i go through is to buy a full system.
· Speed is bliss!
No personnal garuntee here, but I'm pretty sure you'll be just fine with the Arrow Headers. Just a side note: Arrow supplies the majority of World Superbike and Supersport exhaust systems for both factory and privateer teams and the quality is top notch.
1 - 4 of 4 Posts
