Hey all, almost done rebuilding an 02 R1, but I'm not sure the Exup is working properly. I saw another post that says the valve should open fully and then close completely when you turn on the key. I have the covers removed, and when I turn the key, they move about 5 degrees counterclockwise and then back to the "notch aligned with valve cover hole" position. It seems like there should be much more movement to fully open and close the exup valve. I've followed the directions in the service manuals that i downloaded and in other posts on here and it seems like I've got the setup and adjustments right, but it just doesn't seem to operate the way i think it should. If you know exactly how much the valve pulley should rotate when switching the key on, please let me know. Also, if it seems like mine is not dunctioning properly, any suggestions on fixing it? I should also mention that the dash doesn't show any fault codes or anything out of the ordinary. PLEASE HELP!
