I have a 2004 R1 with about 20k miles on her.
OK, so I decided to give it a shot after the exorbitant amount the bike shop quoted me. My first attempt ended up with me taking the tank off and dropping the radiator. Changed the plugs out without gapping them and threw the coils back on. Hooked the tank back in and fired her up. Didn't sound quite right and wouldn't idle proper eventually cutting out. Ended up killing my battery.
Second attempt, I dropped the radiator pulled the plugs out, gapped them (not much of a difference) and dropped them back in this time making sure the coils were screwed on tight. Installed my freshly charged battery and voila she starts right up. All the cylinders seem to fire up just right and no check engine light. Here's the problem, I can't seem to rev her, if i give it gas(real slow, gradually or fast) she sounds like she's choking and cuts out at about 4k's. I do not have the radiator plugged back in and this is the only difference from before changing the plugs. Apart from the bike's battery being removed and plugged back in. I do have a power commander installed as well.
HELP!
HELP!
