For some time now I've had a juddering under heavy braking and tried everything to try and isolate it. Even a couple of mechanics have given up scratching their heads. Now I can see what maybe the issue - the spring clips holding/bracing the pins on the pads. When replacing the pads I noticed that the right side spring clip rattled a bit and compared it's position with the left side rotor. Different. The right has the lip of the spring sitting on the upper line of the 'H' whilst the left is facing off (covering) the upper line. Which one is right? I'd appreciate a close-up pic of a 6 pot caliper - that works - with the spring clip in place.
Cheers
Cheers
