OK, finally got round to doing the -1 sprocket change last Sunday but only today did I get a chance to take the R1 out for a long-ish spin. Some birthing pains (attached gear selector rod to the wrong hole - shifter a pain to reach; too much lube on the chain = rear wheel & tyre caked etc), but overall really pleased with the change, the difference is instantly noticeable, the bike feels great. Also changed the adjuster bolts and put on gold axle blocks and an evotech nut. So far so good.
One thing gave me pause, though - on first start the engine light came on and stayed on for a first 5-or-so miles, then it went away. Got where I needed to go, left the bike for a couple of hours, then when starting it - again got the engine light. And again, after a few miles it went away... Not sure what that is supposed to mean. Bike ran totally fine as well, no issues.
The only thing I thought could be the culprit would have been the bunch of cables routed through the lip on the sprocket cover that need to be shifted out of the way to take the cover off. Thought I might have shifted them loose somehow, but then the engine light went away so I'm baffled. Any ideas?
Another thing is that I had the battery out again; when putting it back in I decided to move the ECU box out of the way to pop on that f**king rubber belt which secures the battery in place. Didn't disconnect anything there, bike works, fuelling is as good as ever - don't think that would have caused the issue.
Ever happened to anyone here? Should I be worried, and if so, what do I need to check?
