1 - 16 of 16 Posts
Hey guys,
I am trying to swap out sprockets and chain but the front sprocket is giving me the hardest time. Any tips on what I can do? Currently have it in neutral on front and rear pit bull stands, with a breaker bar wedged through the swingarm hole and rear wheel (same set up as
). The sprocket is legit not budging in the slightest. Open to any and all suggestions as I feel like I am about to break something in my feeble attempts.
Thanks in advance!
You mean 3/8 to 1/2 right? The socket is quite big.
The reason the air impact works , is that it’s torque snaps the the nut with out trying to turn the transmission.
Discussion Starter #6
Was going to try this Milwaukee M18 impact driver with https://www.homedepot.com/p/Milwaukee-1-4-in-x-1-2-in-Steel-Square-Socket-Adapter-48-32-5032/202562859 since I don’t have an air compressor. Will give it a shot tomorrow and see if I can break it loose. Brian Van gets his off so easily in the video. Maybe I need to hit the gym more 💪🏼
Discussion Starter #10
Impact wrench. The reason locking the wheel doesn't work is the sprocket cush drive.
I tried an impact wrench yesterday, but my 32mm socket is 12-pt and it started to slip. I might strip the bolt trying again with it so now Waiting on a 6-pt socket to arrive in a couple days and will try again. You think hitting it with some PB Blaster over night will help at all? I’m almost at my wits with this thing.
You should be OK with a 6 point, preferably an impact socket but they are expensive. A decent quality 6 point has always worked for me. That nut can be sooo tight from the factory.
Discussion Starter #12
Is there a lock washer on the 2015?
1008096
Looks like a self locking nut. An impact gun should loosen it, but don't try and spin the nut off.
Discussion Starter #14
Jesus, I’ve been using a 32 mm socket and the nut is 30 mm. 🤦‍♂️
Discussion Starter #16
Update: I finally got it off. Not sure what did the trick as it could have been either using the correct size socket, hitting it with PB Blaster to sit overnight, the impact wrench breaking it loose, or utilizing a 30 inch breaker bar for increased leverage. Probably a combination of all of that. Thanks everyone for the suggestions!
1 - 16 of 16 Posts
