1 - 20 of 21 Posts
Oldschool Rider
Cleaning out my garage and here are some parts I no longer need all parts includes shipping to US address.
2001 R1 parts:
Stock complete wiring harness with ECU and relay, parts only not able to test - $100
Stock brake master cylinder with braided lines and blue dot calipers - $100
Stock coil assembly - $100
Carburetors, airbox and throttle cable - $OLD
Miscellaneous covers for the tank, coil and bottom of the triple tree - $OLD
Rear seat - $OLD
1/4 turn throttle with new cables - $OLD
Fuel pump - $OLD
Barnett clutch plate spring conversion kit - $OLD
1013213
1013485
1013486
1013492
Are you ok with shipping to Aussie?
I’m chasing the q/a throttle and Barnett pressure plate.
Email is: oilboiler1216atoutlookdotcom.
Oldschool Rider
I have another member interested in those parts, let me get back to you.
Thank you
Oldschool Rider
Discussion Starter #8
What can you tell me about the carbs - are they stock or have the been rejetted?
Stage one yosh jet kit, k&n filters. I ran a Akrapovic slip on for about 3k miles and upgrade to flatslids and full ti.
1013310
Oldschool Rider
Discussion Starter #9
How many miles on harness?
I don’t know, I bought it as a spare because it’s complete with the ECU and Relays. the only mod I can see is a splice into the tail light with the OEM connector still attached. my guess it was for the integrated turn signal. So the harness is sold as untested part.
thanks
Oldschool Rider
Discussion Starter #10
Thread update.
rear seat - sold
fuel pump - sold
misc covers - sold
1/4 turn - sold
Barnett pressure plate - sold
Oldschool Rider
Discussion Starter #12
It's been awhile, so bare with me, does stage one involve drilling for larger jets?
yes, the yosh MJN jet kit requires a 5mm bore. All the slides are moving up and down smoothly and I’m including the jets kits with the carb. If you are running slip on now this carb is direct bolt on if you want to run full system with pods the kit will give you different options.
Oldschool Rider
Discussion Starter #15
Yes, please note it was not tested. I acquired it as a spare and all OEM connector intact, the only mode I can see is a tap into the rear tail lamp. ECU and relays included.
karl
2000 R1
Are the carbs still available? If so, I'll buy them. Just let me know how you want to handle the transaction.
1 - 20 of 21 Posts
