1 - 11 of 11 Posts
Semi-Amateur Racer
*****EDIT: $550+ shipping.
Appears that these are actually the header/mid pipe from the Yoshi Alpha Ti system and an Arrow can.******
Up for sale is a Ti Arrow system that came off my ‘15, $600 plus shipping.
Reasons why it’s so cheap: the header and link pipe all are for the ‘15+ R1, but the can does not belong to this system. Got it from a friend this way and made it work. Header and link pipes are titanium, can is stainless. Have springs that’ll go with it, but they’re getting pretty worn out. Figured out how to make it work as is, but could really use a hangar to connect the muffler sleeve to the subframe to make it more stable.
Everything is in good shape on it, no damage other than a scrape on the underside of the can (visible in one of the attached photos). Individual bungs on the runners for tuning. Just getting rid of it as I went back to a 3/4 setup with the Arrow Evo2 parts.
Took plenty of photos of it and some of it on the bike to show how I had it installed.
I think this would work for me but it's hard to tell from the photos. Was this a full arrow kit and the end can for some reason was changed? If so which one? Or was this a set of headers and a separate link pipe? I am asking because I can't tell if the link pipe expands or not like it usually does on the full kit. also do you know the side of the link pipe where it fits the can?
ah i see what your saying now. that pipe doesn't have the loops on it for the springs like the exhaust does. not the hugest deal i could weld some on. so yea if you could measure the openings then i guess the inlet and the oil of the mid pipe so i know what other cans will fit. i am trying to play around and mix and match to find on that will meet noise so thats why the questions I'm not trying to be annoying with it.
Semi-Amateur Racer
Discussion Starter #4
Yup, there unfortunately aren't any loops for the springs on the actual can, so used that t-bolt clamp and ran a spring from it to the loop on the link pipe as pictured. Present everywhere else on the link pipe and header as they should be. Should be able to see it in the photos but there are also O2 bungs on each primary for tuning purposes.
No worries on the questions, I'll get some measurements when I get home later today. That's initially why I went with this, much quieter than the Arrow GP2 3/4 that I had on there before. Ended up not liking how quiet it was so I went to the Arrow Pro-Race 3/4, which is pretty obnoxious. Can't seem to find a happy medium, oh well.
Semi-Amateur Racer
Sorry for the delay. Looks like the outlet that goes to the can on the mid/link pipe is just shy of 2.5 inches (first pic). Can (second pic) is just slightly larger the last pic is the end that connects to the header.
Thank you for looking into it. I was looking into why it looked funny to me and I believe what you have it the yoshimura alpha system with an arrow can from an earlier R1 like one that's supposed to be dual cans maybe? I have the same alpha system on the street bike. I just have to look into if the arrow can that I know will pass noise will fit onto that midpipe and I'll get back to you.
Semi-Amateur Racer
Discussion Starter #7
You may be on to something. Hadn’t even thought about it being a different manufacturer all together and after going to look at them, appears to be so. The can, yeah your guess is as good as mine. Shape and end cap though do look like it should have been in a normal mounting position on one side of the swing arm.
Yea I was trying to figure out what was what and judging from the end cap how it's angled a bit more Howard's one side it's like the 09-14 right side pipe it angled Howard's the brake light. Doesn't really matter it's the length I need to quiet it down but if it isn't enough I'll have to swap it for another I know will work so I just gotta make sure that they will mate.
Semi-Amateur Racer
Discussion Starter #9
Bump, $550+ shipping.
1 - 11 of 11 Posts
About this Discussion
3 Participants
RichSC
Full Forum Listing
