My bike has the superbikeunlimited ECU flash, the ECU was sent in by the previous owner. I called superbikeunlimited to ask what the likelihood of them enabling the quickshift feature was before I ordered the quickshifter and the guy I spoke to said they enable it almost 100% of the time and if the quickshifter didn't work I likely installed it incorrectly. So I ordered and installed the shifter, put the pin in the 27 slot on the squarish ECU connector. Grounded it on a bolt near the front of the bike and tested continuity to the negative terminal on the battery with a multimeter to insure that I had a proper ground connection. I also tried it in push configuration and pull configuration to make sure I wasn't mistaking one for the other. All of the times I attempted quickshifting were above 5k RPM and I wasn't able to get the quickshift to work.
I'll happily provide photos or answer questions to help people better understand the issue and if I end up figuring out the issue I'll try to remember to post the solution here.
Thanks in advance.
UPDATE
SOLUTION: I cut the ground wire in half to test continuity from the wire to the terminal connector and the terminal connector did NOT have continuity to the wire. Somehow during the manufacturing the terminal connector wasn't crimped properly to the wire. I cut off the connector that came with the quickshifter and crimped my own connector on and attached it to the negative battery terminal and now the bike quick shifts perfectly.
Thanks in advance.
UPDATE
