That's awesome! Reminds me of when my dad dumped his bike in the living room, dropped the oil on the carpet and rebuilt the engine in the bathtub.Bikes in the kitchen ...I'm figuring this out
So I replaced etv fuse side 60 is gone...now theres a high pitched whining noise under air boxThat's awesome! Reminds me of when my dad dumped his bike in the living room, dropped the oil on the carpet and rebuilt the engine in the bathtub.
Solved err 60 thx now high pitched noise from under air box still wont startAccording to the wiring diagram the oil level sensor goes directly to the cluster....and not the ECU...so it will not stop the engine from starting....
Solve the Err-60 first.
It goes on n onIs the high pitched whine constant and unending, or just for a short while? If it's the latter, it's as tad158 says. If it goes on and on and doesn't stop until you turn off the ignition, there's a problem.
I checked diag 1 n 2 it's within the mark 1.1 and the whine changes as throttle opensThe servo on the throttle body makes a very high pitch noise at all times it is the ETV servo. If I were near my bike I would shoot a video to prove it. Here is a way to test it, and to prove it to your self that your ETV is working.
Turn the key on, let the fuel pump prime (or not in your case). Then listen to the whine. Open the throttle all the way. The noise should change with you moving the throttle. If you want to test the throttle body, use diagnostic mode D1 and D2 will show the TPS and APS sensor values respectively. Tell us what the values are for both of those at closed and wide open throttle, so that we can check that this is working now.
Bike on rear stand in neutral lights ON clutch wires look good side stand wires missingGood that means the ETV is working properly!
Now... is the bike in neutral? Does the neutral light illuminate on the dash? Does the clutch switch wire look intact? Side stand switch wires?
I think it's by passed theres a 2 wire black plug on shifter side of bike that has no plug with wires spliced togetherGood that means the ETV is working properly!
It's got two tires stripped n twisted together...They may have bypassed the switch which you should order and reinstall
Why is it the pump isn't priming I have to run power to green plug red wire with blue tracer to get it to power on
It should prime with the bike in neutral no matter the state of that switch.
Hmmmm...
If you hot wire the pump,
So that's where I was at before the forum...it would...start pop n die ..never woujd it start n idle...I'd have to throttle to get it to start then it would rap up to about 6 grand b die n I kept playing with it like that trying to get it running long enough to get it to idle.....if I spray starting fluid it runs until I stop sprayingIt should prime with the bike in neutral no matter the state of that switch.
Hmmmm...
If you hot wire the pump, does the bike run?
