Hi fellas.
I've got a bit of a problem, and is just wondering if anyone else has experienced anything similar with their R1's/R6's. My R6 was experiencing what I thought was clutch slippage. Accelerating out of 2nd gear, changing to 3rd, the engine revs would stay about the same, though the speed would slowly pick up. The same would happen when shifting from 3rd to 4th, and might carry on in each gear after that. It wasn't so bad at Eastern Creek, but then at Broady 2 weeks ago, it was every single lap. Then, at the end of the day, I couldn't select gears properly, and it was like something was jamming the shifter. I pulled in, and found that I could not select Neutral when the bike was on the race stand. I waited about 10 minutes, then had to really put a lot of weight on the shifter to make it shift gears, and eventually found Neutral. So, I thought I had clutch slip and the clutch was f*(ked, and the jury was out as to whether or not the gear selection problem had anything to do with the clutch at all.
So, today I took the bike down to my Uncle who is a mechanic, and we pulled the clutch out. Turns out the clutch looks almost brand new, and there is no evidence of slippage/discolouration of the plates/warped plates/ broken springs or anything else wrong. While the clutch was out, I also showed him the gear selection problem, so that tells us the clutch has nothing to do with it. I'm going to send him the R6 Full Workshop Manual I have so he can check it out, but in the meantime, has anyone had any problems similar to this with their bikes in the past, and if so what did you do to fix it, and is a new gearbox/rebuild on the cards do you think? We thought also that maybe the oil I'm using (Motul 7100) might have something to do with it, but probably not.
Any useful info or advice would be appreciated.
Cheers.
JJ
Cheers.
JJ
