I recently replaced my generator cover because it was damaged and started leaking. Before I took it apart, the bike ran fine and did not make any noise. I pulled the generator completely apart, lubed everything, and installed the new cover. I did not replace the inner or outer bearing. Today I tried to start the bike after it has sat for 2 months. When it fired up, I heard this loud whine, which seemed to come from the generator cover area. It sounded like the typical Yamaha whine but very loud and isolated. it got really loud as the bike ran and then the bike stalled as if the engine locked up... I can turn the engine over by hand until it gets to the compression stroke, which tells me it is not locked up. The starter will push it to it too then is stuck. However, for some reason the starter went out too. It took quite a while for me to start it. . The starter has died for some reason. Any idea on what went bad? All the bearings seem to be okay. It was dark, the bike only ran for a minute, and that cover was hot... Did yours do this too?
