R1R00kie said:
I just received a new OEM lower for my R1 but it doesn't have the aluminum heat shielding that is on the one I replaced. Has anyone had problems not having the shielding on there? Does anyone know where to get a similar product that I could install on my new fairing? Thanks.
Some after market exhaust system link pipes/headers come pretty close to contacting the lowers, if thats your situation, I'd recomend you add some. If the link pipe/header is not in close proximity to the lowers, you probably won't have an issue.
Heat shielding doesn't come on replacement lowers, mine was minus it as well (its Yamahas way of getting you to buy seperate parts at increased expense).
Check out some discount (motocycle) parts distributors, for cut-to-fit sheets of the stuff, or do as the guys above mentioned, and hit your local auto parts stores :thumbup
