21 - 29 of 29 Posts
My R1 go to warp drive
I'm just being as transparent a I can be so others don't have to "figure it out" on their own. There might also be a difference in what shock you use. FFP shocks like the Penseke or the JRi use lighter springs by design while the stocker or Ktech or Ohlins need a slightly harder spring (by comparing shock to shock ignoring the linkage at the moment). This has nothing to do with suspension needs of the rider/bike/link but rather a simple design difference between the shock themselves.
:tocoo: Use the internet at your own risk.
:eek: The more you know the more confusion there is...
My R1 and I R1
Discussion Starter #23
I'm glad you got the linkage and was able to put it to good use already. What format did you put it in A or B? Also did you do any shock spring change?
Orientation B. Lowered the shock adjustment all the way down. Adjusted ride height withe the linkage. Then set sag.
It’s not drama, I’ll dig up the photos.
Hello hope everyone is well. I’m new to the site. Thank you in advance.
This thread has been very helpful.
I am doing a old Kawasaki fitted with newer suspension project. The 09-14 swingarm is a great looking arm and believe it or not, almost bolts straight onto the kaw frame.
I need to fab up the top shock mount. Which is why I’m asking for your help before I do.
I don’t have Facebook so can’t follow the trend. Hopefully the forum isn’t dead the way the Kawasaki forums are.
Currently the bike is mocked up with 2012 r1swingarm and oem linkage. I also have a soupys adjustable link.
This thread says the performance oriented linkage/knuckle is superior to the oem unit.
Question: can someone provide the triangle measurements of the track unit? The 3 sides of the link hole to hole? I’m assuming it is larger than the oem for more leverage???
Question: what do you like in regards to the swingarm angle topped out or sitting?
Question: am I wrong or does the r1 shock of 09-14 sit fairly straight up and down?
The top of the shock does not seem to be tilted forward nearly/not at all, like other makes of bikes.
Again thank you in advance for any insight or direction. If the superbike or graves unit is sitting on a shelf and forsale, please let me know.
One last thing. I have a linkage from a year that I don’t know too. It’s the last picture.
Thank you
Cmg
Premium Member
Thank you
Cmg View attachment 1010164
If I was home and had my bike in my possession, I would definitely measure that for you.
You should start a build thread here for sure!!!!!!! This forum is still alive and kicking to a certain extent.
Yeah start a thread this is a specific thread topic, you'll get more response asking it with your own thread
21 - 29 of 29 Posts
