1 - 7 of 7 Posts
Bald headed dork
I’ve got a few questions about the installation of some new grips that I bought. I bought the Pro Grip 719 grips since so many guys here recommended them. I also bought a tube of Pro Grip grip glue. However, the small pamphlet that came with the grips says the following: Apply soapy water or alcohol to the outside of the handle and the inside of the grip. Slide the grip over the bar, twisting and pushing.
So far so good. Then it says if the grips came with glue (which these did not) to apply the glue to the handle and the inside of the grip. Then slide the grip on the handle, twisting and pushing.
So which method should I use? I know some folks use hair spray instead of either method. Still other just shove them on with the help of some compressed air. Which method should I use? I want them to be installed properly, but I don’t want them to be a real PITA if I need to replace them later on.
Suggestions? I’m leaning towards the alcohol method, BTW.
Thanks,
Scott
U want some of THIS?
hey scott, i've actually used both methods.
alcohol method is good if you have some glue left in the bike clip ons. the grip might not stick at much if there's no glue there.
hairspray method is quite good. slippery in the beginning, and after it dries, it's quite stable.
grip glue is good too, very very slippery and you know it'll hold.
you can't go wrong with the last two. i hope that helps.
Powered By YamahaR1 Technology
i used the soapy way once.. the grips kept comming loose..
i bought a tube of that grip glue.. worked like a champ.. they
never moved an inch after that..
IXI
:thumbup just got a new set of Harris grip my damn self! I'm just gonna go with the instructions I think...:fact
1 - 7 of 7 Posts
