1 - 11 of 11 Posts
Seduced by the dark Side
I am half way through fitting my Arrow Y pipe (cat remover) and my cans, going o.k but there was no fitting kit with the Y pipe, i.e no clamp for where the Y Pipe meets the mid pipe, nor was the an 8 mm nut to bolt the 2 section Y pipe to the brace at the bottom, no problen as just went to the tool box, It looks a tight fit and seal, but am I right to asume it does not need a clamp on the bootom of the cat, the cat did? If there are any other Arrow users out there, info appreciated
Hi, I have a Arrow full system on my 2004 R1.
As you mentioned, indeed there is no clamp or spring(s)
where the Y-joint meets the midpipe.
rainman 998
Y pipe replacement
Hi,
I am thinking about replacing my Y pipe but keeping the stock exhaust, either Akrapovic or Arrow.
Would be grateful if you could tell me about the advantages or youe experience with this mod
Thanks.
24 Liters
You need a clamp at the bottom of the y-pipe. Stock clamps will attach it to the 2 "branch" pipes.
You won't feel any power gains but you will notice reduced heat on your ankles. The Akra y-pipe is the only one I know of that works with stock cans. I'm sure there are others.
Good luck.
rainman 998
Good luck.
I take it to mean that I would have to get my own clamp where the end of the Y-pipe meets the main pipe. Yes?
Thanks,
Erik
24 Liters
Thanks,
Erik
Correct. The Akrapovic Y-Pipe comes with a clamp, but you could easily find one at your local hardware store. It's just a simple airplane style clamp...nothing fancy. I would buy one that is made of something that won't rust since it is located in an exposed area.
Good luck.
1 - 11 of 11 Posts
