ie., Piaa lights.......Also what type of /model bulbs does the '04 use"?
Thanx in advance
BoogieDown-R1 said:Does this mean after Replacing all 4 bulbs that all 4 lights will be on Low beam?
No, you are simply replacing the bulbs with better/brighter ones. You will still have your normal 2 low beams and normal 2 high beams. But seeing how you will need to buy 4 new bulbs, that would definitely get expensive. DO NOT buy cheap blue Discount Auto Parts bulbs, they will melt your harness. Save up some money for PIAAs. Good luck!BoogieDown-R1 said:Does this mean after Replacing all 4 bulbs that all 4 lights will be on Low beam?
No... The lens/housing are pointed up/down to make it high/low... The bulb itself has nothing to do with it...BoogieDown-R1 said:Does this mean after Replacing all 4 bulbs that all 4 lights will be on Low beam?
