I am slightly confused with throttle application at the point of turning in in a turn. After reading a Twist of the Wrist 2 I currently roll off the throttle up to turn entry, turn and only when I have finished countersteering then begin rolling on the throttle. I do find though that riding this way the bike is still slow to lean.
Some articles I have read promote rolling on the throttle either at the same time or just before turning in to help the front tyre grip by preventing it from being overloaded from the weight transfer caused by rolling off the throttle towards the turn point.
Other opinions I have read state the front tyre can only cope with either weight transfer or changing direction and not both. Because of this I have read that it is better to maintain speed at corner entry to both tyres are equally balance, flick it in and then roll on the throttle to transfer weight to the rear tyre throughout the turn.
I am also confused as to how much of a roll on and how quickly the roll on should be. Do you roll on up to a third, half or full throttle throughout the corner. Do you achieve the roll on in a half second, second etc. Is there a way to judge the rate of roll on. I read Andy Ibbott used only 3 - 10mm of roll on depending on the type of corner which hardly seems full throttle. Any opinions on this? I appreciate any help please.
