1 - 7 of 7 Posts
Hi everyone, I have a 2006 R1 that cranks but doesn’t start
It’s been sitting for a while
Just put in a new battery
Any ideas ???
U need to be checking the obvious first, petrol,A spark ?
Sent from my SM-G930F using Tapatalk
I will check the basics first but these bikes may have a common problem that happens all the time
It’s new to me, I never had a R1 before
Discussion Starter #4
Super Moderator
Check for fuel, spark and air. You need all three of these basics.
The fuel pump should prime on turning the key while in neutral and with the kill switch set to on.
If that check passes, Go into diag mode:
  • check that all injectors click when tested
  • check that all plugs fire when tested
  • check that the throttle responsds when tested.
Google Yamaha r1 diag mode, and you'll get a hit of how to enter diag mode and what tests to run for what components.
Sent from my SM-A205F using Tapatalk
1 - 7 of 7 Posts
