1 - 3 of 3 Posts
Nothing but balls
First gear and second gear fine through high revs, but with 3rd when I get around 8-9,000 rpm, starts cutting out, like not getting enough gas. Have changed the fuel filter and with first and second fine, I think is an ignition problem. Don't these have two stage ignition "things", don't know the name and could that be causing my problems,
Thanks
Nothing but balls
Discussion Starter · #2 ·
is it carbs
why is it cutting out, can it be the carbs or floats need ajusting???
Mr.International
mine doesn't quite cut out but lose much power. Have Keihin flat slide carbs. Thinking Its an adjustment problem. I hope. Let me know if you find anything out, and I'll do the same.
1 - 3 of 3 Posts
