I wish I had my bike license and joined this forum back in 2003 when Keith Code was posting. I have read the Police Road Craft book, Lee Parkes Total Control and Andy Ibbots Performance Riding techniques. These books do not address the one fundamental question I would like answered. How hard should you Countersteer? do you push harder at higher speeds? or does the gyroscopic precission help the bike to lean at faster speeds? how far do you push the bar, is it more important to physically turn the bars or is the amount of pressure more important, does a greater steering angle translate to more lean? how quickly you push the bars does this make the bike lean quicker, further or both?. I know that as the bike speed increases so does the force causing the front wheel to keep straight. I also know that the faster a bike goes the stronger the castor effect and gyroscopic precission which causes the front wheel to track in the direction of the curve. Some riders believe once you set your lean angle by countersteering you should release some or all of the pressure on the bars to allow the bike to use its castor and gyroscopic precission to turn the wheel in the direction of the turn. The bike apparently will not straighten up if you release the pressure after setting the lean but will continue on its chosen arc. This is the web site where I got this information from http://www.geocities.com/american_mo...rashcures.html
can someone please answer the above regarding how much force is required to countersteer, how quickly and hard it should be applied, how quickly and when the pressure on the bars should be released? I appreciate Keith Code is not posting any more but I am certain the rest of you are very knowledgeable and should be able to help me please.
