That's why the ZX won, hm?NONE!!! The R1 got pulled by the ZX everytime there wasn't a draft involved!
Actually it was a great race and good team driving by the Yamahas. Gobert shot to first from fourth after Hayden was blocked by two Yamahas. The 10 did seem to be able to pull the R1 when in the straights.Juerg said:That's why the ZX won, hm?![]()
Why yes they did........:factR1R00kie said:Actually it was a great race and good team driving by the Yamahas. Gobert shot to first from fourth after Hayden was blocked by two Yamahas. The 10 did seem to be able to pull the R1 when in the straights.
Yep - I was there and saw it. It appeared the ZX10 could make a little ground on the high bank and onto the straight early in the race. Then, the Yamaha drivers caught on and started riding the same line. The true Yamaha advantage was in the infield. I sat in turn one and saw the Yamaha's laid over, hard on the binders and just outdrive the Kawasaki's. By no means was it a land slide victory - but having Yamaha come out on top was a thrill!GPgofast said:ANY 1 of the top 5 could have won. They were all covered with a blanket. Gobert was in 5th coming onto the banking and benefited from the 4 bike draft in front of him. From where I sat, the ZX's had the motor on the R1's and would consistently pull a gap coming on to the banking only to be drafted back. There was NOT much HP difference in these bikes. GP
Chucklemaster said:Yep - I was there and saw it. It appeared the ZX10 could make a little ground on the high bank and onto the straight early in the race. Then, the Yamaha drivers caught on and started riding the same line. The true Yamaha advantage was in the infield. I sat in turn one and saw the Yamaha's laid over, hard on the binders and just outdrive the Kawasaki's. By no means was it a land slide victory - but having Yamaha come out on top was a thrill!
Aside from the all mighty draft both bikes had advantages & disadvantages in certain areas of DIS but as we witnessed the 10r did not get left behind what so ever!! and as you said considering GMS has had the R1 since about early Nov that makes the 10r even more impressive with its late pilot prod models used by Kawasaki.Balistic said:Just a small reality check about the Graves Yamahas VS. the ZX10. graves has had the new bikes for quite a few months and is the acknowledged MASTER of how to make a Yamaha R-1 fly.
Kawasaki on the other hand is using pre-production bikes because the ZX10 release was delayed. Not only that they have to go from scratch with an all new platform, not an evolution of a proven design.
The ZX10 will be there on the podium plenty this year. Did you happen to notice how the well the all powerful and fully developed GSXR did:no
Will
