1 - 20 of 1078 Posts
//Low-Life\\
First of all this is not a 15 min. job but take your time and u can finish it in 1 night. Start by removing the tank, it has a quick connect fuel line and wont leak gas when you disconnect. Also buy a box of bandaids!!! Youll need them!!!
*This link will take you to changing the plugs*
http://www.r1-forum.com/forums/showthread.php?s=&threadid=110766
//Low-Life\\
Discussion Starter #14
The smog plates alone should produce at least two to three horsepower because your getting a cooler air charge in the airbox.
Thriller
Nice write up! Thanks
//Low-Life\\
Discussion Starter #18
Ive seen Gixxer 1k pump out as much as 4 HP on the dyno with a piar valve mod so I am optimistic about 2 HP on the R1:beer
