As I have mentioned before. I have no fuel gauge on the R1 RN19 and I installed a fuel gauge today.
Tools/parts needed:
Koso Fuel gauge item no. SKU: BA003250
Yamaha FJR1300 fuel pump assembly (used) part no. 5JW-13907-21
Philips/JIS screwhead driver
Allen key 5mm/ratchet
Fuel catch tank/fuel (5gallon) can with funnel
Wiring and clamping
First remove the seat (2bolts 10mm)
Second remove the fuel tank. Four bolts, front one side two plus trims philips one bolt behind
Disconnect the vent hoses, fuel line and plugs.
Siphon all gas out or use a fuel line to pump it empty.
Using this guide (thanks to Fjorn) I found the switch 12V+ in the wiring loom.
Remove the fuel pump assembly.
Slide the low fuel light assembly sensor out of the pump assembly and swap over the FJR1300 fuel float.
Cut the green wire on the low fuel light and connect it on the fuel gauge meter.
Install the Koso meter on your own taste I have installed on the left side just above the high beam light cover.
Manual: https://kosonorthamerica.com/wp-content/uploads/2020/07/BA003250.pdf
Extend all three wires as this is too short for a R1.
RED - switch 12V+
Black - Earth
Green - Connect to the green wire on the plug of the pump assembly
Follow Kosos manual to set the correct fuel level.
I used USER mode (hold button long for 3 secs)
I know my full tank is 21 Ohm and empty 141 Ohm
Screen will ask you to put the float on empty. Do that and push to confirm.
It will save the 21 ohms on the meter
Then do for the full 141 ohm so put float to full
141ohm will be registered after pushing on the button.
Remove or tape over the low fuel light on the instrument cluster as it will keep warning as the oem wiring is cut. Remove/tape off the original low fuel light as this not working anymore.
Do work neat all the cables together and leave the signal wire a bit more slack when installing the tank.
That is it you have installed the Koso fuel gauge.
Do all the steps reversed and your done.
Tools/parts needed:
Wiring and clamping
HOW TO: Install HealTech GIPro-X Gear Indicator
HealTech Electronics, makers of the SpeedoHealer, now has the GIPro-X gear indicator. This is a relatively small unit for easy positioning and is easy to read. The installation is fairly simple as it plugs into your harness and you need to tap into two wires. NOTE: There have been a few...
www.r1-forum.com
RED - switch 12V+
Black - Earth
