281 - 300 of 322 Posts
doing bike maintenance today and for shits n giggles i removed one of the smog block off plates just to have a look see....filthy as hell
anyone out there that has their AIS system laying around that doesnt want it? I think i tossed mine in a move a couple years back...but wanting to mess around with it a little bit. let me know. thanks!
kickin' at the darkness
sitting on bike, under left air intake... you gotta pull the rubber snorkels to see it.. :yesnod
My R1 owes me money!
What? Do you mean the marble trick?
I do not know this marble trick your talking about but when everyone installs blockoff plates it says to be sure to plug the holes on the bottom of the air box. couldn't you just plug the holes on the bottom. What is the need to block off the top and the bottom? When the channel your blocking is connected?
Master of the Obvious
I think the 'marble trick' is sticking marbles in the tubing of the AIS to prevent air flow from the pump. AIS stays in tac but is deadheaded. No block off plates required... Go the block off plate route tho.
The hole on the air box that should be plugged is the suction lead to the AIS. A rubber plug will do. The one on the very bottom can be plugged by slipping the plastic bracket off the AIS, you need to turn it a bit to line up the tabs to remove it. It has a white dimple or whatever IIRC.
Tin Foil Hat
Removing the AIS will also save you a little bit of weight as well. Honeslty, the plates are cheap and worth it. The way you're talking about, wouldn't work that well. You'd want to do the marble trick, and then plug that hole as well.
Pretty much what he said.
