vulaevu said:
Hey pro's.. i purchased a wrecked 01 r1 thats probaly been sitting out in the winter months and other seasons for at least a year.. tried the battery, dump old gas out and still cant get it starting.. is it the carburator??
You need fuel/air, compression, and spark for the engine to run. You might want to start with making sure the battery is well charged first.
Then if she still doesn't run I'd check on the spark first. Pull the plug wires and use an extra plug to see if you have spark. Just make sure the plug is grounded.
As for the fuel, you may have to clean the carbs. Just take them off the bike and use some carb cleaner. Make sure you get the jets well. Depends on how bad they are. May have to rebuild them.
She will start. :yesnod She just needs some love. :thumbup
